Hi. I have a 3 monitor setup, 2 of my monitors on one graphics card and working, and the other i am still setting up. I can't put another GPU into my PC as there is only one PCIe slot, so I'm trying to use a virtual display software to create a virtual display, and stream it to my other PC connected to the 3rd monitor over VNC/similar.
I have already tried ZoneOS ZoneScreen, but the support simply isn't there for the newer OS versions. I'm running Win 8.1 x64, and I couldn't achieve it.
I pretty much need another piece of software that can create a virtual monitor, or something similar. Note; all I need is software for a virtual screen/graphics card, I can easily set up something to stream it.
Does anyone have any ideas of virtual monitor drivers/software that will work in 8.1?
Thanks in advance.
Thanks in advance.
