Vizio subwoofer replacement wont pair
So I got this Vizio soundbar s3821 from a friend and I decided to buy the subwoofer separately since the original one died. At this point I dont know which of the two is broken but theywont pair. The soundbar works fine by itself and the sub I got is the same model # as the bar. Ive tried everything and anything I could find online including bar software update. Any sugestions?
Yes I did. And after following their step-by-step intructions, which I've did before calling, they said that the life expectancy of the equipment was 3-4 years and I should buy a new one.
Good lord they actually said that? Don't even pretend they have a long lasting product?
If this thing pairs like standard BT, I would FORGET all existing connections/reset to factory, and try again from the top.
