Voice doctor. Help!!!
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.soyo (More info?)
I've got a K7VTA pro that is talking to me, however, I can't hear it. Is
there some way to connect a speaker to the board? Thanks.
jw
> jw
Have you connected the speaker that is supposed to make the beep sounds
and other system warnings to the Motherboard? That is the lousy low
quality one that comes with most cases.
The connections are in the same general area as the powerbutton
connection and the LED connections. It is explained on page 10 of the
manual. The connection is the same for the original K7VTAPro and the V1.0.
