VOIP w/Distinctive Ring?
Archived from groups: comp.dcom.voice-over-ip (More info?)
Al Franz wrote:
> Any of the VOIP services support Distinctive Ringing?
I think "additional users" on ATT CallVantage can have
distinctive ring. (This is a shared single line, not a 2nd line)
There is an additional fee too.
Lingo does, standard feature.
Depends on the equipment you're using. My Sipura SPA-2000 ATA has a choice
of 8 different ring cadences. The Grandstream ATA-486 is limited to the US
single ring style.
Ivor
Guess I don't understand how the equipment on my end will help. Doesn't the
provider have to support some type of distinctive ringing so that you can
have multiple phone numbers on 1 line.
Ideally what I would like is to have several phone numbers coming into 1
line and be able to detect which number is being called prior to answering
the phone. Can this be done with VOIP currently or possibly in the near
future.
"Ivor Jones" <ivor@despammed.invalid> wrote in message
news:3ailvvF67f24oU1@individual.net...
> single ring style.
> Ivor
"Al Franz" <albert@nospam.netmation.com> wrote in message
news:HIudnWKAstuU6dnfRVn-sw@comcast.com...
the
> future.
I think there are two different kinds of "distinctive ring" being discussed.
You are talking about something that would be implemented by the provider.
You would have several DIDs, each directed to one line and each assigned a
distinctive ring by the provider. Equipment like the Linksys PAP2/Sipura
SPA2000 have a native feature called "distinctive ring." This is implemented
on the user's end. There is a table where you assign a distinctive ring
(from a list of 8) to a set of up to 8 incoming numbers. For instance if
your mother call you from 555-1111 you can assign that to ring #1 and if
your brother calls from 555-2222, you can assign that call to ring #2, and
so on. The ATA simply looks at the CID information and if it matches a
number on the list, the ring cadence assigned to the number is used.
For example of how "distinctive ring" are configured on the Siprua 2000,
take a look here:
http://www.sipura.com/support/
> the provider have to support some type of distinctive
> ringing so that you can have multiple phone numbers on 1 line.
What do you mean multiple phone numbers on one "line" - do you mean one
account, one broadband connection, what..?
The ringing cadence to the phone, assuming you're using an analogue phone
plugged into an ATA, is generated by that ATA, not the provider. Some are
user-programmable in this respect, some are not.
> into 1 line and be able to detect which number is being called
> prior to answering the phone. Can this be done with VOIP currently
> or possibly in the near future.
Not into one line, at least not as far as I know. I have two phones on two
different accounts operating through the same ATA with a different ringing
cadence for each one.
Ivor
>> Doesn't the provider have to support some type of distinctive
>> currently or possibly in the near future.
> discussed. You are talking about something that would be
> implemented by the provider. You would have several DIDs, each
> directed to one line and each assigned a distinctive ring by the
> provider. Equipment like the Linksys PAP2/Sipura SPA2000 have a
> native feature called "distinctive ring." This is implemented on
> ring (from a list of 8) to a set of up to 8 incoming numbers. For
> instance if your mother call you from 555-1111 you can assign that
> to ring #1 and if your brother calls from 555-2222, you can assign
> that call to ring #2, and so on. The ATA simply looks at the CID
> information and if it matches a number on the list, the ring
> 2000, take a look here:
Not only that, but you can assign a default ring to both line 1 and line 2
so even if you don't set a ring for a particular number as you describe,
you can still set the line to ring in a particuar way as a default.
Ivor
The Cisco ATA-186 supports selectable ring cadences, so you'd just need the
selection to be indicated in the call setup. Whether any commercial VoIP
providers do this, I don't know, but if you roll your own, you sure can.
miguel
Hit The Road! Photos from 35 countries on 5 continents: http://travel.u.nu
Latest photos: Thailand, Indonesia, Malaysia, Israel, Palestine
In message of Fri, 25 Mar 2005, Ivor Jones writes
I guess he means something similar to BT's CallSign in the UK.
David
> David
Well with a Sipura SPA-2000 or similar you can have two "lines" but these
terminate on two separate RJ11 sockets into which you plug two separate
phones. You could use something like a BT Converse 2025 2-line phone
though I suppose.
Ivor
I'm pretty sure SunRocket offers a number of distinctive rings with
thier service.
> the provider have to support some type of distinctive ringing so that you
> answering the phone. Can this be done with VOIP currently or possibly
> in the near future.
Don't think that's possible, but you can setup multiple accounts, and
setup you phone to use different ringtones, it the phone supports multiple
lines.
I'm using a Sipura SPA841 utilizing 4 accounts at 3 different providers in
two countries, and it works great. ;-)
> the
>>future.
Interesting, because on our VOIP system the CID information is not
available until the SECOND "ring". So I can't see that it could work as
you describe under such a system.
If you use Windows, you can look for distinctive ring info here:
http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q240996&
Rick Merrill <rick0.merrill@gmailNO.SPAMcom> writes:
>> on the user's end.
....through the POTS port.
The "trick" is to have the device use the CID as soon as it's
available (as soon as the call is initiated) instead of waiting for
it to finish emulating the POTS version of it.
--kyler
