volume control not working
jspin98
4
I plugged in speaker set with subwoofer, and i cannot adjust the volume. it is either mute or max. My drivers are up to date
After you are done with reinstalling the driver, just restart the computer and check if the sound is working fine.
Only if its not working after the above reinstalling process, do the below:
Uninstall it again, remove the speaker connection from you PC. Plug back the speaker and then restart your computer and use the default windows 10 driver(it will detect automatically). I have heard the similar problem before and using the windows default driver helped.
Good Luck.:) Peace.
Good Luck.:) Peace.
