After building my computer just a few days ago I discovered the front audio input for my headphones is picking up what seems like frequencies from other computer parts in/outside the case. For example, it has a very quiet static noise all the time but if I plug my external harddrive into the USB port right next to that audio jack(on the front panel) I get crazy frequency noise and it's LOUD even if my audio in control panel is muted or not. I also get this if I hover my mouse over different links in my web browser 😵, it seems to distort the sound, it's very strange and truly annoying. I had re-routed my audio cable to go behind the motherboard plate and stay away from as many components as possible, this did quiet it down some. I do not believe this is a software issue but more a hardware issue. Is there something wrong with the internal audio cable that came with my case like the insulation or whatever? How can I fix this? Also, when my music is playing and I might lower the volume the static is loud and clear as if nothing was playing at all. I swapped to AC '97 to see if that would work and doing that made even more noise so I swapped it back to the HD audio.
I appreciate any input,
Thanks!
Thanks!
