Question Volume really low on pc even with Loudness Equalization
Jun 29, 2019
5
This problem has been going on for a year or more, and I dealt with it by using Loudness Equalization, Now it doesn't seem like that works anymore either.
I thought the problem was in my new headset but I realized my old headset had the same problem too, So I decided to plug my new headset into my IPhone and tested out some music, the audio was great and the bass was good too, So its definitely not the headset. I tried to update drivers and uninstall/install, I checked all volume bars, I also did sound trouble shoot nothing seems to have fixed it, To note I got a new motherboard because my old one wore out but the old motherboard had the same problem too. My new motherboard ->https://www.newegg.com/p/N82E16813157681?Item=N82E16813157681And my old motherboard -> https://www.newegg.com/p/N82E16813157636 .
I'm on Windows 10
But yeah I tried everything that people recommended online but nothing seems to work, I don't know if this is the right part of this forum to post this
I didn't wipe my files when I installed my new motherboard so its probably nothing physical could be something wrong with my settings or something I just cant find it. @EDIT I forgot to mention there is rattling in headset when I use volume boosters on chrome but when I put phones volume on full blast while playing music no rattle happens
Sorry for responding so late. Yes if you mean the two usbs and two headers for audio and mic, but I am not sure if its the same brand, my case is a Phanteks Eclipse P400. I forgot to try the front panel when I was trying to find out the problem, when I did the music became louder (which is a good thing) could that be it? thanks for reply
