Archived from groups: alt.internet.wireless (
More info?)
1. Ahhhh - you need to change the login password to the ISP on the WAG54G -
it is doing the connection to the ISP, not your PC. This probably explains
why you can't connect to the net through the WAG54G.
2. Is 109.113.132.134 in the range reserved for local subnet addresses? The
192.168.x.x range definitely is, but I'm not sure about 109.113.x.x and I'm
not sure what the effect of using it would be. I would stick with the
192.168.x.x range, at least until you've got it working again.
3. Get the wired connection working first, before moving on top the wireless
connection. If you can't connect to the WAG54G (using a wired connection)
then this implies that your PC IP address isn't recognised as part of your
subnet by the WAG54G. Are you using DHCP - on both the WAG54G and your PC?
Or if you are allocating the IP address statically then is it set to a
suitable value?
4. If you still aren't connected then I would be tempted to reset the WAG54G
(hold the reset button down for 10 secs) and then re-enter al parameters.
You will need to know your ISP username, password, VPI and VCI - your ISP
can tell you suitable values for these.
"Gordon" <gordonlr@DELETEswbell.net> wrote in message
news:5bl6s0tfmk5ndchibil45vac7k9ppv2ftg@4ax.com...
> On Fri, 17 Dec 2004 21:06:56 -0000, "nospam" <me@privacy.net>
> wrote:
>>If you can't connect to 192.168.1.1 then this implies that your PC IP
>>address isn't valid for your LAN subnet.
>>Apparently if the PC can't get a valid IP address from the DHCP server
>>then
>>it uses a 198 (?) address. This seems more likely to happen if you
>>connect
>>through a wireless link to the WAG54G rather than through a wired link.
>>So:-
>>Try connecting via a wired link, then check your WAG54G settings for
>>username, password, etc
>> These could have been lost if :-
>> -someone had reset the WAG54G making it lose these settings.
>> -you left remote administration turned on, and a hacker has
>> adjusted
>>them for you.
>>If you still can't connect then you could try resetting the WAG54G and
>>re-entering the parameters from scratch.
>>Ummm have you paid your broadband bills recently?
>>Hope this helps
> Thanks for this response. I will try to give you more information
> to go on.
> My first thoughts were that I was in trouble because I had
> changed my password for my internet service. I did the password
> change, using this computer. But, I didn't open the WAG54G setup
> screen and change the password there, if that is a requirement.
> The DSL failure didn't show up until a day or so later, but this
> may be because the DSL service never blinked during this time, so
> a new connection did not have to be established. And, yes, I am
> paid up with my DSL service provider. This is a part of my
> regular phone bill, which is direct debited to my checking
> account and paid almost instantly, when the phone company submits
> their bill.
> I am not able to get into the Linksys Setup screen at all, so I
> can not verify any of my settings. A printout that I made several
> months ago, when I first set this up shows that I changed the
> Local IP address from 192.168.1.1 to 109.113.132.134. I don't
> remember just why I did this, but it may have been because of
> some other problem and I was just groping for a work-around.
> Anyway, I can't get to the Setup screen even with this Local IP
> address.
> I'm presently working from and through my desktop, which is wired
> to the WAG54G, not through a wireless link, although I have tried
> getting through with my laptop and the other desktop, both of
> which are wireless connections. Same thing...I can't get to the
> Setup screen. I've never had remote administration turned on, so
> this surely isn't the source of the problem.
> When I turn the WAG54G off, then turn it back on, the green
> lights all blink in accordance with the information given in the
> manual. The only thing that fails to go to completion is the red
> internet light never turns green.
> The WAG 54G has not been reset. This is a three computer home
> network setup, and I'm the only one that messes with the WAG54G
> setup. I haven't touched the reset button.
> All three computers can communicate with each other, so the local
> setup is not malfunctioning. I just can't get my DSL connection
> up and running. But, I can dial-up through this same phone wall
> outlet, so there must not be a problem with the phone line.
> Can you think of anything else I can try before I give up and
> punch the reset button?
> Thanks for your help.
>>news:sig6s0t507vogc85uh5q587hsrgrer3vsn@4ax.com...
>>>I have had my WAG54G Wireless - G ADSL Gateway set up and in
>>> operation for about 3 months. It was working very well until
>>> yesterday. The DSL Internet light switched from green to red and
>>> my connection has been down since.
>>> I tried to go to the configuration address, http://192.168.1.1/
>>> and check the settings, but can not get through to this address.
>>> I get an error message screen that says the site is not
>>> available. What am I doing wrong, or failing to do right? Any
>>> suggestions???
>>> I'm down to my dial-up connection, and getting anxious.
