Wall mount monitor sideways?
sickb
20
Hello, i have a dual monitor wall mount (got 2 24") but there is a big space between.To cover it i have to pull the monitors very close to me and its not practical.
I found a way to put them side by side very close to wall (in portrait ) so i was wondering if i put the mount sideways , will i encounter any problems?
You mean have the mount vertically but the Monitors horizontally? If the mount can handle the monitors, then I don't think so. Unless there are some difficulties when it comes to moving the mount, other than that, if the mount can handle it, then you're fine.
Yes you can post links as long as they are not fishy sites xP
About the mount; It looks like you can simply rotate it? I mean, you can put the mount sideways and rotate the monitors horizontally, so no need to drill any holes. Unless I misunderstood.
