Knowing your info is kind of required and idk why its happening.
I use to run it on my old rig but this new build? Refuses.
i open it, it loads the small popup then stalls at 70% monitoring.
it wont pass that point and pressing any kb key or clicking the box anywhere shows "not responding do you want to close program or wait and see" and task manager shows not responding.
I've only had this new system for like 3 weeks.
specs:
ryzen 5700x
MSI X570S edge max wifi
32gb ballistix ram (2x16gb)
m.2 boot drive (WD back 770)
2 1TB hdd (for stuff i dont need use often/game library)
GTX 1060 6gb
CPU is not even OC'd (as MB's cpu boost had be disabled when i learned it had too agressive unervolt and caused me WHEA errors)
Ram is also only using the XMP (3200) which is mainly my goal of why i wanted to OC system as plenty of room there.
image of issue:
specs:
ryzen 5700x
GTX 1060 6gb
image of issue:
