Having endless problems with this wireless network adapter,
It will freeze my PC for a few a seconds every now and then.
This card just doesn't work well, I'm using Windows XP SP3,
I've already formatted and reinstalled everything 3 times,
I've used the drivers that came in the CD and
then the latest from Realtek's website none of them solve
the issue, card willl freeze everything on the PC for a few seconds,
mouse & keyboard included. If you disable the card everything
works fine and computer can run everyhting without any
problem whatsoever.
Seeing as how I'm not the only one with these problems,
(use google and you shall see...)
it is clear these Realtek 8185 wireless cards are not working,
they should be recalled and our money refunded.
For the record, I'm never going to touch much less buy anything with
a Realtek chipset inside wether it be wireless cards or motherboards.
The offending hardware is:
Realtek RTL8185 54M Wireless LAN Network Adapter
Complete Specs:
http://152.104.125.41/products/productsView.aspx?Langid=1&PFid=1&Level=6&Conn=5&ProdID=35
Stay away from it like the plague, you've been warned.
problem whatsoever.
Complete Specs:
