Water block for the 1080ti
Apparently they want an actual picture of the PCB board AND VGA card. Sent them a capture from my screenshots I got from the NVidia website. They (the Compatibility inquiry form) kicked it back. So never mind on the update. Sorry
Finally got a reply. Don't think he gets their configurator doesn't work. It seems the universal will work for one. Any one speak Slovenian to translate the message into something they can understand? Or I'm confused.
EKWB Support (Grega) (EKWB Support)
Mar 14, 11:27 CET
Dear costumer,
thank you for contacting us.
Sadly, we don't offer full cover waterblocks for the GV-N1080XTREME W-8GD so there is a connectivity issue with two GV-N1080XTREME W-8GD if you would like to use our universal GPU waterblocks.
Do you plan to use existing water cooling solution on the GV-N1080XTREME W-8GD or do you plan tu use our universal GPU waterblock solution?
If so, then please go through the custom loop configurator with one grahpics card and send me the link to your confiugration (share your loop option) and I'll check for possible solution to add a second graphics card.
Your RAM is also not compatible with our cooling solution (due to higher module size) so I would not recommend to choose RAM option on step2.
Best regards,
Grega
Aries1aa
Mar 11, 02:22 CET
Tried to use your Custom Config. and for the GPU and the # of RAM it wouldn't let me input information, just got a circle with a line through it.
Case: Enthoo Evolv ATX Glass
MB: GA-Z270X-Gaming 7
GPU: GV-N1080XTREME W-8GD , 2 of them
# of RAM: CMU16GX4M2C3000C15R , 4 of them
This is my first liquid cooled rig build, HEP ME.
