I'm building a new system Sunday and have a question about configuring the CoolerMaster MasterLiquid ML360R RGB CPU water cooler to my Gigabyte X570 AORUS Elite AM4 Wifi Motherboard and other case fans.
What would be the best/fastest way to configure this to sync with the ARGB Fusion on the motherboard? I'm thinking I don't need to use the CoolerMaster command hub that comes with the cooler.... Is the best way to just chain the fans together and plug the ARGB directly into the ARGB Fusion 2.0 slot on the motherboard and no need for the CoolerMaster Hub?
First time building with a liquid cooler or incorporating RGB into a build so any advice is appreciated.
Thanks!
Thanks!
