Hey All,
I've got a Deepcool GamerStorm Genome II ROG case - had it for some time but due to having a bit more time on my hands recently, I've been tweaking things.
Long story short, I had the AIO cooler from the case plugged into the CPU header and the radiators fans in the CPU_OPT header so both were running well but not optimal. I also had these set to DC (whoops), but realized that I don't want the AIO on PWM, so thats when I moved the AIO to the actual AIO pump fan header. I immediately noticed significant amounts of noise from the PC and after a little trial and error realized that the AIO header always runs at 100 (as designed) and when my AIO cooler runs above around 65% it makes a lot of noise.
I'm seeing a few bubbles in the line, so I'm thinking it's air, but its a lot of noise, to the point that it sounds like an old HDD processing at 100% constantly. Video below.
View: https://youtu.be/Z6XmhRI0EBE
If it is air, how can I fix it?
Help!
Help!
