Water Cooler powered by 3-pin header?
SargentOcculis
6
I am getting a water cooling kit from corsair. The pump is powered by a 3-pin header on the motherboard. But there is no 3-pin header on the motherboard I have. Can i just plug this into the 4-pin PWM CPU header? What can I do here?
sweenytodd
898
221
Yes, read the manual. It say you can plug that into any motherboard header, 3 pin or 4 pin. I am currently using a Corsair H80i and the 3pin is plugged into my main 4pin CPU header.
