Welcome to the ongoing build-log for my system, the Red-Chalk. It details from when I first started water-cooling and covers pretty much all the goings on with my rig since then. All my long winded thoughts, idea's and explanations are here, so a light read this is not :lol:.
Big thanks to Moto, Scopey, Rubix , Big-Cyco and amuffin for helping me out when I first inquired about water-cooling, and many others who I have learnt from since.
The XSPC Raystorm 750 RS360 water-cooling kit.
PrimoChill PrimoFlex Pro LRT tubing red, 7/16ID 5/8OD. 2m of it.
And a Killcoil.
Well, I took the plunge and got all that water-cooling stuff yesterday, and now it is assembled, leak tested and probably not fully air bled yet if the pump noise means anything :lol:.
As promised, here is my build log and hopefully all the pictures you could want.
This is before I started pulling everything apart, my dual fan Hyper 212 Evo doesn't even know what happening yet.
Stripped out all the unnecessary stuff, the HAF-X is starting to look empty.
My 3570K tries to hide itself under a layer of thermal paste (which is fairly well applied, I wasnt expecting that good an application considering it was the first time I had done it. Little bit of spillage though)
Remove the Thermal paste with some White Spirits cleaning fluid, and its revealed.
Took the opportunity to clean my PSU. Full modularity is so useful.
Time to get down to business. First the radiator had its stock XSPC push fans screwed to it and then was mounted in the case.
Protip: When water-cooling in a HAF-X with a triple rad, you will need the top 5.25" bay clear if you want to fit a radiator+fan in there, even for slim radiators. I was lucky my fan controller doesn't take up the whole bay, but if you had in optical there and every other bay was full, you'd be in trouble.
Mounting the pull fans, two Coolermaster Silent red LED fans and one mystery red LED fan I found in an old PC one day.
The Raystorm CPU block did go on with some trouble. The LGA1155 backplate was somewhat difficult to place on the back of the mobo, and that caused havoc when you try to screw in the block and the plate has moved. Got it in eventually though.
One uneventful (and undocumented unfortunately) pump/res mounting later, I got down to putting in tubing.
ProTip: Measure everything! Once that tube is around the barb, it aint coming off without a fight. Stuffed up the connection between the radiator and pump/res, spent the next 20min pulling the tubing off each end. Makes me wonder why we even need clamps.
And a Killcoil.
