Water Cooling Configuration ? Best Way ?
WilliamSoh
26
Hi , I need advice for my water cooling routes for this specs
Specs :
CPU : Intel Core i7 4930K @ 3.4GHZ OC @ 4.4GHZ
Ram : 32 GB G.Skills 2133MHZ DDR3
GPU : Gigabyte GTX 1080 Xtreme Gaming 8GB GDDR5
Case : Phantek Enthoo Evolve ATX Tempered Glass
Water Cooling Set :
1x 360mm Radiator ( Top )
1x 240mm Radiator ( Front )
1x Bykski GTX 1080 Water Block
1x EK LGA 2011 CPU Block
2x Water Cooling Pump
routes that im thinking :
1. Pump => GPU Block => 360mm Radiator => CPU => 240mm Radiator => Back To Pump
2. Pump => GPU Block => CPU => 360mm Radiator => 240mm Radiator => Back to Pump .
Please advice on which is the best routes for lower temps and good looking in a tempered glass case .
It's certainly worth a shot, I suppose. I just don't want to be the one to get my hands on a $500+ unit only to have it either not work or stop working.
I'm at work right now - when I get home I'll call him and see what size his chillers are. If they're suitable for the wattage we need; I'll test it.
When I do my thermal load testing, I purchased some aquarium tank heaters (ironically) that I a was able to disassemble and solder the load switch circuit to always remain on. Mine are 300w and I have a variable AC transformer which allows me to adjust exactly how much draw they utilize which should be fairly equivalent to thermal output in watt draw. Pretty simple.
Dont set it below Room Temps , to avoid water moisture condensing on your motherboard.
I figured that as much. First step is obtaining one of the chillers, though. If that can't happen; this conversation is null and void, sadly.
smart !
Any news ?
