Water cooling first time help
eacl87
So I have read the sticky and have decided to build a custom wc loop for my cpu. I have a 2500k and am using a Bitfenix Prodigy. I'd like to know if the following components are alright/compatible and if I need anything else to get me started:
Radiator:
http://www.frozencpu.com/products/14856/ex-rad-332/Alphacool_NexXxoS_UT60_Full_Copper_Dual_120mm_Radiator.html
CPU block:
http://www.frozencpu.com/products/14186/ex-blc-971/XSPC_RayStorm_High_Performance_Acetal_CPU_Liquid_Cooling_Block_-_Intel_Sockets_LGA_115x_1366_2011.html
Pump/Reservoir:
http://www.frozencpu.com/products/21022/ex-pmp-251/EK_D5_X-RES_Top_100_w_D5_Vario_Pump_EK-D5_Vario_X-RES_100_incl_pump.html
Tubing:
http://www.frozencpu.com/products/17896/ex-tub-1627/PrimoChill_PrimoFlex_Advanced_LRT_Tubing_38ID_x_12_OD_-_10ft_Retail_Pack_-_Elegant_White_PFLEXA10-12-W_w_Free_Sys_Prep.html
Fittings:
http://www.frozencpu.com/products/5480/koo-71/Koolance_38_x_12_10mm_x_13mm_ID_G14_Threaded_Nozzles_Pair_NZL-V10.html
What do you guys think? Is that okay? Am I missing something? Any piece of advice/comment will be appreciated (also, bear with my terrible english). Thanks in advance
Dont forget a pump mount! and also like man of chalk said.. FANS!! fans are SUPER IMPORTANT!!! make sure you match PWM pulse width modulated.. or 3pin fans.. Most important with the fans is the CFM. different radiators have different specifications as to what type of airflow they need. i also like to use 120mm fan grommets.. i know most pople dont.. but they do make a slight difference in vibration dampening. Also, keep in mind MORE FANS coming in than blowing out, that will help slow down dust accumulation. good tubing thouhg.. that is what i use.. but all of my stuff is EK and bitzpower. keep us posted with pics!! or feel free to PM with questions!
