I just bought some compression fittings and some tubing for my water cooling build. I do not know lots about water cooling and after purchasing everything I realised the tubing was 3/8" ID 1/2" OD whilst the fittings are 3/8" ID by 5/8" OD. Will the tubing still work? The tubing I think is slightly smaller than the fittings so it can stretch right?
Thanks for any help
Thanks for any help
