Water cooling on wall mounted computer
Fireger
97
Hey guys
as the title says, ill be water cooling my computer which is wall mounted
I have all the components mounted onto a board with some acrylic
Was just wondering, with the radiators, how should i have the fans orrianted, and how far away from the acrylic do i need them?
Mainly so they dont heat up the acrylic to much, and there is also enough airflow for the heat to escape.
thanks in advance
Greetings!
I would recommend that you have the fans direct the air away from the wall and toward the plex (into the room) for better heat dispersal, and an inch to 1 1/2" should be ample gapping from the plex.
Hope this helps!
What do you mean upwards? im mounting the radiator perpendicular to the ground, so i can either have fans pulling 'towards' the wall, or pulling away from the wall
Greetings!
Hope this helps!
