Hi guys, this is my first post as I noticed you guys were a great community of PC builders and modders. So I am hitting up my second build, and it is my first water cooling build. I will be using the In Win 909 case.
Parts List: http://pcpartpicker.com/p/TzZPxY
Ignore the storage, wireless adapter, and power supply, those are for my uncle. This brings me to my questions.
1. Pump.
Will be using EK-XRES D5 pump (https://www.ekwb.com/shop/ek-xres-100-revo-d5-pwm-incl-pump) with a regular or verticle fan mound depending on where you guys think I should mount it. I'm thinking mount 1, as I think it would allow more natural air flow from bottom of case, and the mount is cheaper. But dont forget I have a long GPU so I dont know if it will fit 🙁 .Help me decide.
https://gyazo.com/0874189052013bf56b2937f45823b5d1
2. Dye.
For now I will definitely be running distilled water and Mayhem's kill coil, but in the future i would like to run Mayhem's ice white combined with a mix of some UV dyes. I would like to know how this would affect tubing and stuff, because I know it stains, but then why is everyone using it if it stains? I just want that UV stuff in tubing but no staining to parts .
3. Tubing.
First time water cooler here. Really want to run acrylic, because I have UV in my case, and the crystal look to it. I have a couple of kits in mind to buy for bending, but first I want to address should I even be doing hard tubing. Also please tell me if I need any angled fittings to make the build easier to route the tubing in.
So here's the pipe I have in mind.
https://www.ekwb.com/shop/ek-hd-tube-12-16mm-500mm-2-pcs
And the fittings.
https://www.ekwb.com/shop/ek-hdc-fitting-16mm-g1-4-green-5439
Please correct me in these choices if I am wrong.
Here is the bending kit I am probably going to get.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106403&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-DIY+Cooling-_-N82E16835106403&gclid=Cj0KEQjw4J-6BRD3h_KIoqijwvkBEiQAfcPiBQDOjCgfq2bvSjqCRwyYahP925dNfi1biRENwk5WdGYaAiFv8P8HAQ&gclsrc=aw.ds
I see its not for acrylic though. So if that doesn't work, this one will do.
http://www.performance-pcs.com/monsoon-hardline-all-pro-deluxe-bender-kit-1-2-x-5-8-16mm.html
This heat gun.
http://www.performance-pcs.com/monsoon-hardline-pro-heatgun-kit.html
Stupid question but do I need gloves and sandpaper? If I need the sandpaper can I use some I already have?
Thank you guys so much if anyone answers, I hope you guys really are a cool nice community. If so I have found a new home!
-hunt
1. Pump.
2. Dye.
3. Tubing.
And the fittings.
This heat gun.
-hunt
