I've got a watercooling kit that I bought a few years ago in a sale and it's been collecting dust ever since so I want to put it to use, it only has a block for the CPU so it's probably not designed for GPU and CPU cooling but I don't mind getting newer parts (i.e a bigger pump, a GPU block, more piping etc) to bring it up to standard. If I'm going to do a custom water cooling loop I want to cover both CPU and GPU.
I currently have a Gigabyte Aorus RTX 2080TI Xtreme and an Intel i9-9900k with a corsair H110i, so it probably isn't even worth upgrading (if it can even be considered an upgrade) which probably leads you to ask why the hell I want to replace it all, the answer is I get bored easily and want to do something to my PC.
My main question is, will a GPU water block fit onto a GPU with a third party cooler? Does the thirid party add to or modify the PCB or do something that would stop a GPU block fitting properly? Thanks for any advice in advance
