Question Water damage (?)
romelvelaj
25
Okay so:
Recently, I dropped a full glass of water down my table which proceeded to drip directly into my PC case, down to the very power source.
Thankfully, the computer wasnt turned on and i immediately unplugged everything. I then let everything dry and booted the pc the next day. No luck.
I called a friend to bring me his power supply, but he had a different idea. He opened my pc, and took out a blue plastic thingy. The computer suddenly worked.
Now, it turns out it wasnt a perfect solution. The pc doesn't turn on as it once did, I need to press the button multiple times. Also, It takes 10-20 seconds longer to boot.
Idk what that blue plastic thing was, or if it was important at all. Does anyone know what I can do now?
Any eventual damage was done at very beginning when water reached some elements and shorted them.
Best way to test is to breadboard system adding or changing any parts one by one starting with PSU. It helps if you have a system speaker/buzzer connected.
Secondary damage is done by replacing that blue jumper with the power ON:
"The thing is, whenever I put the blue thingy back on it's place in the Mb, the power immediately shuts off. As if it was obstructing the electricity flow inside the whole computer. "
Can you read the motherboard model? May need to remove GPU to see. We could use manual to determine blue jumper origin.
The blue jumper was at the DRCT pins. i have no idea what that is.
The motherboard model is an ASUS M5 a97 R2.0
guys my PC is working again. I have no idea what happened, i literally only let it rest for two hours but the signals are being sent again.
I'm happy but not satisfied, because it doesnt' feel like a long term solution...
Then either:
You're putting this unknown jumper in its unknown space on the wrong pins.
or
The board is toast.
That's what I don't get tho: the board isn't completely toast. It is working right now, in fact I am writing on said damaged PC. It doesn't work perfectly, the Hard drive didn't function but I made it work. I can even game...
I dont know if this will last, but so far everything is working.
Identify the problem before applying a solution
Is it the drive?
The cable?
The motherboard port?
Neither cable nor port. I switched out cable and port, the hard drive is here it's just weird. I can start steam games but not GOG games and it's just so muddled and bizzare, it's hard to place the problem..
The jumper is normally on Pins 1 and 2 of the CLRTC header:
