Question Water Pump Fault?
Mar 25, 2020
Hi All,
I am experiencing a weird random interval 'groaning' like noise from my PC, which appears to come from my AIO cooling radiator.
I am thinking its the water pump that might be faulty, or dust is built up in the fans?
Youtube video is provided with the noise -
View: https://www.youtube.com/watch?v=OlqAj8j52M0
Will do a blow out this weekend, but wanted to get some thoughts!
Thanks,
t0ph88
Hi All,
Thanks,
t0ph88
I can see a lot of dust on radiator, best to take it out, take fans off and clean everything nicely. Might as well change paste while you are at it.
Reactions: t0ph88
So to confirm, blow out didnt change anything.
The PC is only 6 months old so there wasn't a huge about of dust build up.
Looks to me like it may just be a pump fault...
