Its for the uni project. Drip irrigation agriculture working model.Make and model of your water pump? Is it to use to cool your PC via watercooling? If so, why are you looking at USB powering the pump and not running off of molex from the PSU?
What current does the pump need? I would not be surprised if the current is higher than what a Type A 5v connection can deliver. If that is the case you could damage any USB source you connect it to.
Need to know the wattage or maximum Amp rating. If it’s going to take more than 2 Amps then this is a bad idea. 5v @ 2A is 10 watts which I’d expect is low for a pump.Well its marked 2.5-6V
DC Voltage:2.5-6V
Maximum lift:40-110cm / 15.75"-43.4"
Flow rate:80-120L/H
Ok if that is max current at 0.18A you are ok, must be a fairly weak motor.I only have this for the refference
