So this is one of my setups for my water-cooling I want to do (maybe either white or purple depending).
So that's the stock fan setup I chose for this case.
So I color coated everything (except mine will be a black Switch).
The Red Ones are Exhaust:
140 mm - Rear with a fan pushing air out.
360 mm - Along the top of the case, with Fans pushing hot out.
The Orange ones are Components:
VGA (Graphics Card)
CPU
RAM
The pump & reservoir in a 5.25" bay with front led control.
I was thinking of adding one on the bottom for additional 140 mm as an intake, but it might make it look really messy. Thoughts?
VGA (Graphics Card)
CPU
RAM
