Watercooling: Bitspower fittings for my custom liquid loop
blackdevilmt
144
Final version of my drain loop what do you think?
https://www.dropbox.com/s/0e2rxhod11d6utu/dada.png
I was am going to do the loop like this:
Compression fitting<T fitting 1 <Male To male<reservior
Male to Male
Bitspower Valve
Compression fitting
Clear Tubing to see if there will be any leaks from the valve
Compression fitting
Xspc Plug G 1/4< T-fitting<Xspc Plug G 1/4
What do you think about this setup,I pretty much like it. I can't simplify anymore the draining and creating a leak free system.
Latest posts
