[SOLVED] watercooling system for my pc
qe58hmr
19
hi all,
https://pcpartpicker.com/user/qe58hmr/saved/ the gpu is msi 3080 suprim x 10g
this pc i build 2 days ago while playing games i get 70-80c depend on the games im playing but the fans noise driving me crazy i cant take it anymore so i looked in the internet and this what i found what u guys think i dont have alot of choices cuz he gpu is new and there not alot of water blocks in the market
https://www.ekwb.com/custom-loop-configurator/shared/oW5fd1becdbbbf8
and this the gpu waterblock
EK-Quantum Vector Trio RTX 3080/3090 D-RGB - Nickel + Plexi
So your question is will it fit or is this any good? :)
Have the EK full cover block on gpu here and very pleased. EK makes very high quality although notice some have very big dislike of them maybe price. Before I build a custom loop I look at gpu blocks and your right there isn't a big variety. Could be maybe there are just too many different layouts from AIBs to make a custom block design for each of them. Reference gpu's seem to have some offereings and some of more popular sellers. Maybe this why not see the AIO coolers for the gpu's.
@qe58hmr
I'd choose other brands such as Bykski or Barrow. they're cheaper and have excellent quality. Bykski has blocks for 3080.
btw, the link you've posted doesn't cool the gpu, it only includes cpu water block. so you're looking for this:
https://www.ekwb.com/shop/ek-quantum-vector-trio-rtx-3080-3090-d-rgb-nickel-plexi
this is the Bykski equivalent:
https://www.amazon.com/Bykski-Coverage-Water-Gaming-N-MS3080TRIO-X/dp/B08LPVP5JC
47$ cheaper.
msi Trio and Suprim 3080/3090 have all same layout and waterblocks.
