Question Way lower FPS than expected
Aug 1, 2024
I'm getting sub 10 FPS on The First Descendant despite having a 3080 Ti which should be more than powerful enough to handle it. Any idea why this could be the case?
Here's my Userbenchmark: https://www.userbenchmark.com/UserRun/68346698
CPU Intel Core i5-10400F
GPU Nvidia RTX 3080-Ti
RAM Corsair Vengeance LPX DDR4 3200 C16 2x8GB
PSU CORSAIR - CX-M Series CX750M Semi-Modular Low-Noise ATX Power Supply
HDD Sandisk S3 1T02 1TB
How old is the PSU? What GPU did you have prior to the RTX3080Ti? If you perform a discrete GPU upgrade, did you run DDU prior to dropping in the new GPU?
