Way to spoof USB stick to appear as DVD/CD drive?
SHADOWSTRIKE1
Commendable
May 4, 2016
12
Hey guys, first time here. Hoping someone can help me out.
The company I work for in their IT department is about to issue some software to all desktops that will prevent employees from inserting and using USB thumb drives. The idea is to add another way to prevent employees from taking any company/client info. Great idea, but it provides my IT team with a problem... with this new software, it causes an issue for us as we can not transfer needed files to repair stations off of our USB drives.
My idea is to find some way to spoof our USB drives so that Windows detects them as a DVD or CD drive, which in theory would bypass the security software. The goal is to not have to install any additional software on the client computers, like daemon tools, etc. We're looking for a plug-and-go option.
Note: before anyone asks, yes, the software may have an option for an admin account to allow a connected USB drive to be used, but we are unsure right now, and we want to be prepared just in case.
Those software are usually user based. we have it install at our company too, and I can use my usb drive just fine.
Other than that can't help you "hacking" your security software
You probably know this already but I think that the "powers that be" need to have a get together....
Your concerns are quite valid.
Do the desktops have writable DVD/CD drives? If someone wishes to steal data then they would just use that drive. Not as easy or as convenient but end results would be the same.
Pretty good chance that someone dedicated to getting data would find a "USB" workaround or some other spoof. Either a hack or phishing in some manner.
And someone really needs to sit down and throughly test that "software" with and without admin rights.
Not so concerned about the concept per se but the implementation could be messy. And you will be in the middle.
Hopefully someone higher up (your boss) will listen and let you or someone on your team really work things out beforehand.
