WD 2 TB external HDD is not getting detected - It's visible in Disk Management and only Delete volume and help options are enabled when I right click on the partition.
More over Active@ Disk Editor shows the volume is damaged (under the status)...
Can you please give any tips to recover the volume.
I tried WD utility to check the disk and it looks ok 🙁 http://support.wdc.com/downloads.aspx?DL
