[SOLVED] WD Black SN750 1TB Slow write speed
Jan 15, 2020
Hello.
I installed a new WD Black SN750 1TB on my desktop. And I checked the speed.
The result is below. I think max speed is fine, but 4KiB is very slow especially write speed. I don't know what is the problem.
The SSD is installed on Gigabyte AB350 Gaming 3(Ryzen 5 1600X) and I installed another 3 SSDs on motherboard.
[Benchmark picture]
Your safe mode results are what you should be getting all the time, yeah. It means software of some sort - an application or driver - is interfering with 4K writes. An example would be a backup agent (e.g. Acronis), Anti-Virus, things along those lines.
Thank you for your reply. I didn't think about testing on safe mode.
I have tested on safe mode.
Seq Q32T1(Read/Write) 3456 / 3016
4KiB Q8T8(Read/Write) 1617 / 1555
4KiB Q32T1(Read/Write) 376/338
4KiB Q1T1(Read/Write) 53/199
On safe mode, the 4KiB write speed appears about two times faster than normal windows mode. So, is this caused by my windows system? And are these speeds normal?
