Question WD Blue SN550 wont properly wake from sleep inside a Razer Blade advanced
Apr 5, 2021
4
I recently got a new Razer Blade Advanced 2019 (RZ09-03017) and decided to upgrade it's storage. I decided to go with a WD Blue 2tb NVME ssd (SN550). Everything worked exactly as expected, except the sleep mode. Whenever it wakes from sleep, the screen will randomly go black for about half a second every minute or two. Restarting the laptop fixes the issue, at least until you put it to sleep again. I tried uninstalled and reinstalling windows, drivers, changing power settings, and several other things to no effect. I put the WD Blue into my desktop rig to see if it would have the same effect, which it did not. The issue did not occur while WD Blue was installed in any other computer besides my Razer Blade. I've tried more than a dozen solutions and honestly have no clue why it's doing that. I've just been using hibernate but I'd like to get the sleep function working again, if possible. Any suggestions or help would be extremely helpful as I'm completely stumped.
Doesn't sound like a ssd issue. put the old ssd back in and test
I put it back in and didn't experience the same issue. However, I'd prefer to keep the new one in as it has 8x the storage capacity as the original drive. Though I can't say for certain, I'd probably agree that its caused by something in the Razer Blade and not the SSD, I'm just not sure what.
