WD Green 2TB WD20EZRX Problem
HUNTER_SG
Hello I have 250 GB hard drive were Install 32bit win8 and i bought 2 tb WD green I was Fallow
http://wdc.custhelp.com/app/answers/detail/a_id/3865/se...
This step But During Formatting Pc Off Due To Cut Off After i on PC again NTNG happen even There is showing logo of win8 and only black screen
And i remove WD hard drive And Used Old 250GB Seagate HDD Working and win 8 also..
i try to install os With 2 TB there is same Problem Only logo than black screen
And WD Hard drive showing in Device Manager But Now In Disk management and this taking to time to open but after open not showing 2 TB hard drive....
now Plz Help Me
PLz PLZ PLZ
Try plug in other SATA port, if the drive (2TB) shows up in the Disk management but you can't do something on it like format or open. Then you are better to return it because the drive has problem.
K I try n tell u work or nt bt if this nt work do u have any idea???
