Question WD red slow or not detected after power outage
Sep 24, 2018
41
I have a 3gb internal WD red that became slow and unresponsive after power outage
and sometimes its not even detected by windows
it doesn't make any noises and smart WD scan shows healthy
but when I try to access it it will freeze the my computer explorer while trying to access it
error check freezes while cheking for errors
sometimes it shows up sometimes It doesnt
sometimes the folders load fast sometimes they load half way and other half takes forever to load.
accessing files is very long as well
what can be the issue ?
ok so I know when hard drive goes it usually starts making noises
this one doesn't make any abnormal noises on startup or otherwise
its starting smooth and does just normal crunching during access no needle bouncing no loud scratching or anything else out of ordinary
what does that mean
if it suffered a partial crash, your remaining time to access anything could be quite limited, so, get what data you value from it while you can, and refrain from any surface checks, detailed tests, etc...
If it is locking up when reading, that is NOT a good sign, short of perhaps testing WD's warranty claims, depending on it's age..
how do I find a proper controller board for it?
is there a software thet will show me information I need?
im still able to access it at the moment it just doesn't copy some files when I try to copy them(it gets stuck)
