Question WDS bridging troubleshooting between TL-MR3220 and ML108
Sep 10, 2019
Hello:
So, I tried to connect thru WDS protocol this two routers mentioned in the thread tittle, but keeps giving me irregular connection until it doesn't connect at all.
Here´s the Syslog of the secondary router (TL-MR3220):
1st day 05:47:08 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
1st day 06:05:48 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:05:50 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:05:52 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:05:56 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 06:05:58 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 06:06:00 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 06:06:00 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 06:06:00 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
1st day 06:25:10 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:25:12 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:25:14 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:25:18 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 06:25:20 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 06:25:22 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 06:25:22 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 06:25:22 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
1st day 06:45:02 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:45:04 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:45:06 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 06:45:10 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 06:45:12 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 06:45:14 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 06:45:14 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 06:45:14 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
I firstly put the secondary router under the IP address: 192.168.1.150
The IP address range in the main router goes from: 192.168.1.2 thru 192.168.1.199
Then made the WDS connection.
And finally disabled the DHCP protocol on this router.
Please help me. I´ve tried everything to fix this.
Could it be the main router that its too old to take this WDS configuration.
Regards;
RM
Have you tried another known working ethernet cable between main router and secondary router?
What ports did you use to connect the two routers?
Did you reserve the secondary router's static IP address (192.168.1.150) on the main router via the secondary router's MAC?
And that static IP address should be outside of the DHCP IP address range allowed to the main router.
Do you need that many DHCP addresses?
If not, change the main router's DHCP IP range to something like 192.168.1.10 - 192.168.1.199 and then use 192.168.1.2 as the static IP reserved for the secondary router.
Hellooo.
Thanks for your reply. I will answer under the questions you put.
I did the connection wirelessly because both routers are separated about 100ft from each other, so ethernet cable connection is not that simple or practical.
Not doing the connection via cable this question is null.
Didn't knew you have to reserve it, just thought it will assigned that IP address and renew the permit constantly and that´s it.
I followed your suggestion, changed the DHCP IP range of main router to 192.168.1.10 to 192.168.1.199 and changed the secondary one to 192.168.1.2 and reserved that IP address in the main router.
Do you believe this will allow the connection not to drop? It usually dropped about 3 or 4 hours since the secondary router was rebooted. So I guess I will have to see how it behaves.
Here´s the syslog since the change has been done. Does it look normal to you?
# TL-MR3220 System Log
# Time = 1970-01-01 0:09:57 598s
# H-Ver = MR3220 v2 00000000 : S-Ver = 3.17.1 Build 140929 Rel.40245n
# L = 192.168.1.2 : M = 255.255.255.0
# W1 = DHCP : W = 0.0.0.0 : M = 0.0.0.0 : G = 0.0.0.0
1st day 00:00:07 OTHER INFO System started
1st day 00:00:17 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:00:17 SECURITY INFO PPTP Passthrough enabled
1st day 00:00:17 SECURITY INFO L2TP Passthrough enabled
1st day 00:00:17 SECURITY INFO IPSEC Passthrough enabled
1st day 00:00:17 SECURITY INFO FTP ALG enabled
1st day 00:00:17 SECURITY INFO TFTP ALG enabled
1st day 00:00:17 SECURITY INFO H323 ALG enabled
1st day 00:00:17 SECURITY INFO RTSP ALG enabled
1st day 00:00:19 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:00:21 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:00:25 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:00:27 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:00:29 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 00:00:29 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 00:00:29 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
1st day 00:00:39 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:00:41 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:00:43 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:00:47 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:00:49 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:00:51 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 00:00:51 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 00:00:51 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
1st day 00:01:31 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:01:33 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:01:35 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:01:39 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:01:41 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:01:43 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 00:01:43 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 00:01:43 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
1st day 00:02:53 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:02:55 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:02:57 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:03:01 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:03:03 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:03:05 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 00:03:05 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 00:03:05 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
1st day 00:04:45 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:04:47 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:04:49 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:04:53 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:04:55 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:04:57 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 00:04:57 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 00:04:57 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
1st day 00:07:07 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:07:09 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:07:11 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 0
1st day 00:07:15 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:07:17 DHCP NOTICE DHCPC Send DISCOVER with request ip 0 and unicast flag 1
1st day 00:07:19 DHCP NOTICE DHCPC DHCP Service unavailable, recv no OFFER
1st day 00:07:19 DHCP INFO dhcpc_ipc_data_rcv_router 677 : current network type = 0
1st day 00:07:19 DHCP WARNING dhcpc_ipc_data_rcv_cable 443 DHCPC:web server static route number is 0
Regards;
RM
