Question We have an Excel pros on here - need help
SaltyUser199
41
14
4,535
To reference a number in a cell, you would generally simply say something like: =B63
That spits the value out of what is in cell B63. Nice and simple.
But I want to change the "63" reference to a different number, which number I can change in another cell. So let's say I plugged "30" in cell Z1. Using the above methodology, I would think I would put in something like =B(63-Z1) and have it spit out the value in cell B33. But that does not work.
Anyone know how I would do something like that?
=INDIRECT( )
Here, the values are in cells B20 and B22.
Variables in F1 and F2
Result in B10
The formula in B10 is =INDIRECT(F1&F2)
Change the value of F2 to 20, and B10 changes to 400
If you want to add two cell values together, the target cell (where you want to have the result) must include the command/formula.
For example; target cell C87 + target cell C86 formula would be;
=SUM(C87+C86)
And if i put that formula to e.g cell B55, the B55 cell displays the result of adding both cell values together.
Subtracting would be:
=SUM(C87-C86)
=INDIRECT( )
Result in B10
USAFRet, you are awesome, thanks so much. That is definitely helpful. I might have other questions, given that I may have not asked the correct question, but let me work on my spreadsheet and I'll follow up if I didn't quite get the question right on my end. Thanks so much!!!
=SUM(C87+C86)
=SUM(C87-C86)
Thanks Aeacus, I think USAFRet covered it, but I sure appreciate the help!!!
Reactions: Aeacus
