Hello all,
I have a problem getting good signal to my wireless 4g/LTE router. I live in a rural area and i guess there arent many towers in my area so i get weak 4gLTE signal on my router. When i say weak i mean the speed will vary between 0.5-5 mbps and sometime no signal at all. I learned that puting the router right against the window will boost the signal it is picking up but not by much. So i thought I would need to put antennas on it since it only came with internal ones. So i removed antennas from old router and put them on the new but nothing changed.. Do i need to do anythin to configure them? Because i entered the router settings menue and didnt find andything regarding antennas.
Another suggestion was to put antennas on the roof and run cables down to the router which is inside the house? Is this applicable? Can i do it with homemade stuff without having to buy expensive gadgets??
Let me know what you think
- Router model: Huawei B612s-51d
- Gadgets connected to router usually: 4 phones 1 tv 1 laptop.. But rarely all using at the same time
