Question Webcam Advice Needed for my Logitech C922 Pro Stream Webcam (C922x)
MasterYoda327
226
6
10,585
I have a Logitech C922 Pro Stream Webcam (C922x). It is the version of the C922 that comes with a tripod. I have had this webcam for approximately 5 years. It still works and is rated 1080p/30fps and 720p/60fps. I plan to replace my current gaming PC in the near future with a newer gaming PC. I am also considering moving up in display resolution from 1080p to 1440p for the monitor display. I have considered the possibility of replacing my webcam with a webcam with 1080p/60fps capability. However, I don't do live streaming for games or anything else and I only once in a while do video calls via Zoom or Skype. Would it be worth upgrading to a newer and more advanced webcam or should I hold onto my existing webcam? If yes, what webcam would you recommend? If you say I should hold onto my existing webcam, will it work with Windows 11?
Thanks.
