Question Weird AIO Problem
May 27, 2025
Hello everyone! I just bought a new build, the specs are
AMD Ryzen 7 9800x3D
ASUS ROG STRIX 650E-F
GeForce RTX 5070 TI OC
Phanteks Eclipse P400A
Corsair Vengeance 5200Mhz 32GB DDR5 Ram Be quiet! Pure power 1000 watt psu
and a corsair icue h150i elite rgb
Everything is connected properly, however when i start the pc only the pump sounds like it runs, the corsair fans are spinning very slow and the case included phanteks fan doesnt spin at all. If i then disconnect the USB-C cable on the pump, the fans on the front speed up, the phanteks fan still doesn’t move. There’s no video on the monitor either, i tried reseating RAM, still nothing there. What could the problem be? Help is very very much appreciate
tried plugging the monitor cable into the GPU as well as trying the integrated graphics, still nothing.
Did you assemble the system? If so, was the BIOS updated to the latest version prior? Out of the box the B650 chipset will not support the 9800X3D processor without a BIOS update.
You can use this guide;
View: https://www.youtube.com/watch?v=frQApIktgyM
to help flash the BIOS to the latest version. The board might be different but the principle remains the same.
Reactions: Sooth3
Hello and thank you for your assistance ! I built the system myself, it’s not my first build but it is my first time encountering this issue so i was and still am very lost.
The BIOS were not updated yet, however would that be able to cause the weird fan issue as well? I also forgot to mention that there are no debug LED lights lighting up.
I will try updating the BIOS when i get home today and let you know if it works, thank you so much!
AMD Ryzen 7 9800x3D
Aren't you using Icue software for fan and RGB control?
https://www.corsair.com/ww/en/s/icue
