Hello all,
So about a 9 months ago I moved from NY to Pennsylvania. The specs of the system I had at the time was a X299 MSI Carbon Pro AC with an 7820x. It was powered by a Corsair RM850x Gold edition, with 32 GB of 3000 MHz of Corsair Vengeance RGB ram, and an MSI Lightning Z 1080 Ti. The monitor I use is an ASUS PG279Q.
Basically ever since I moved here, every now and then my computer would boot but my monitor would show no signal. The post LED code showed nothing out of the unusual. Now if I were to leave it on for fifteen to twenty minutes or so and hold the power button and reboot the computer, it would boot perfectly fine. This issue has become more persistent. I have changed the motherboard to a Gigabyte X470 Gaming 7 WiFi with a 2700x. I also changed my power supply to an EVGA 1000W gold rated with no success. I have tried running mem test on each stick on each slot, all showing no errors on the test. I tried different outlets with no success. I tried different ports on the GPU as well with no success. I am unsure of where to proceed with this, I am on the latest bios and driver's as well. The only things I haven't changed are the GPU/RAM/HDD/SSD.
