When i was putting on a vr headset, somehow the pcie connector (2pin of 6+2) came loose. This obviously cut out the display but also my fans ramped up really loud. I had ensured the connector was in correctly as this is a 1 week old pc build. After this was fixed (i completely switched out the cable for another one), my peformance of gpu and cpu was worse, more gpu and cpu utilisation aswell as temperatures. I reinstalled gpu driver and the temperature issue has fixed but not the utilisation. For example, on Planetside 2 on all settings maxed i would get 50% gpu utilistaion at max and 30% cpu with second monitor connected, web tab open and discord open. Now i get 98% usage most of the time aswell as 50% gpu usage.
My specs are
4060 ti
Ryzen 7700x
32gb ddr5 6000mhz
4tb m.2 ssd
My specs are
4060 ti
Ryzen 7700x
32gb ddr5 6000mhz
4tb m.2 ssd
