Weird MOH:AA prob...Fatburger, Help!!
BGates2B
371
Well, I did it. I upgraded my nephew's PC and threw on XP for him.
I re-installed MOHAA on his PC, and tried it before copying over main\saved and main\config folders. What was happening was that a window would pop up before starting stating "network connections" There is no NIC card in the PC, but the game would not run for several seconds (feels like minutes) until that window disappears.
I copied over the old saved files and config files figuring it would correct that problem, but it didn't
Anyone have suggestions on how to get rid of that network connection windows on game start?
<A HREF="http://www.anandtech.com/myanandtech.html?member=87962" target="_new">My Rigs </A>
Thanks, but it doesn't try to dial out.
Is that normal?
What about patch 1.11? Will this stop it?
The following is from mohaa.com
Q: When starting the game, the Windows auto-dialer starts and freezes or crashes my game. Why is this?
A: If you are experiencing a freeze or crash while starting a game, it may be due to a conflict between the Windows auto-dialer and Medal of Honor Allied Assault. To alleviate the problem, you should set up your computer to never automatically dial an internet connection. Please follow the steps below.
The MOH: Allied Assault Patch v1.11 has been released. Get it here. But is only available for people using the US or UK version of the game. New changes in v1.11:
Stand-alone game server that runs without CD, mohaa_server.exe.
Fixed bug in pak file search order
Fix for spaces in rcon commands, fix for rcon data transmission
Fix for rcon status command
***Fix for the dial-up networking problem when playing single-player.***
Fix for in-game server browser always auto-refreshing
In-game browser shows version information on incompatible servers, and sorts incompatible servers to the bottom
Fix for running servers from machines with multiple IPs
After reaching an error screen from the in-game browser the game goes back to the browser, rather than main menu
Fixed lag when a bomb was planted and the entire planting team was killed
net_ip reflects what ip is actually used for the game
gamespy uses the ip set with net_ip, if any
Can follow players from the other team when your entire team is killed
The multiplayer dial-up connection fix.
sv_privatePassword and sv_privateClients work to reserve spots for admins
Added proper disconnect and error screen display for when game refuses client connection
Muzzle flashes stick to weapons.
Localization code rolled in (and new localization file to work with altered system)
Removed old Q3 skin code to save memory
Fixed rare visibility glitch with lean
Fixed rare instance when AI would suicide with grenades
Fixed rare instance when an effect would flicker
When a server drops below sv_fps clients get a "slow server" message. This shows up in single-player developer mode. Disable message by setting cg_drawsvlag to 0.
Dynamic light fix for better spotlights
Added protection against malicious names in multi-player
Spectators can no longer telefrag players
Fixed bug with forcemodel and spectator
Strings are now localized as entire sentences, using &&& as a non-localizing wildcard match
Fixed some memory leaks
Oh, I'm sorry. Did I accidentally blow your head off.......again?
