Hi everyone!
I have an issue with my 6 months Old PC build by CLX gaming
When I boot the PC sometimes boots straight into the BIOS, or tells me CMOS was reset please check settings in BIOS. Then after rebooting, PC boots into OS but then my Mouse freezes every couple seconds, then works again, then freezes again.. Keyboard and everyother usb device works.
I tried different mice, different usb port, driver updates/reinstall, heck I even did a fresh windows install again. In save mode mouse works perfectly fine. Anyways when I reboot the pc again there is a 50/50% chance that everything works now if not I have to reboot the PC for a 4th time and then finally everything works and the PC behaves as it never had any issues.
What could cause this behavior I basically got into a routine now to boot 4 times to be able to use the PC..
Oh and small update since yesterday my PC randomly started to boot by itself even though it was shut down and not sleep mode.
I went ahead and turned off fast boot and changed any settings in the BIOS to prevent it from waking up or booting via USB or system fault.. since then it seam to not boot by it self anymore but the other issues especially with the mouse freeze is still there..
Here are my specs:
Aorus z490 waterforce, (custom watercooled)
Intel i9 10900k (custom watercooled)
2x 2080ti nvlink (custom watercooled)
128 GB ddr4 RAM
3x 2tb m.2 nvme ssd
1200W powersupply
Here are my specs:
128 GB ddr4 RAM
3x 2tb m.2 nvme ssd
1200W powersupply
