Weird problem with my computer
ChaosSaber
60
I am having some issues with my comp, every hour at 7 mins after, my net disconnects me, I have done a virus scan and its some type of timer that was installed, it was fine when I went to bed at 1:30 AM but this morning it started doing it, this isn't the first time, but this is a clean install of win7, if you need my comp specs just ask me, anyone have any ideas of what it can be or whats doing it?, also I don't have many progs installed atm, I have 6 other comps online and they do not disconnect from the net
But that error started on the 22th, this new prob just started this morning, last time it done this I had malware but this time none of my scans are finding anything, I tried AVG, Malwarebytes and that scan you told me to do
I did a little studying on this issue and detected a small bit of information with my experiece with computers.
Go to Task Scheduler and view active scheduled tasks. I presume you would find something named along the lines of "netdisconnection"
I also have a theory as to why it happens 7 minutes after instead of right at the hour.
When this virus/malicious program was installed, it likely took effect at Hour:07 AM/PM and set itself to go off every hour. You will have to manually end this task first then delete the virus, deleting the virus may not do anything.
Compromise! The creator of this discreet virus (assuming it is) is not trying to view your personal information- he just wants to be annoying (troll/hacker). The easiest solution in my eyes is to create a batch file to fix this problem.
(modify this to meet your ssid)
:1
netsh wlan connect=SSID
goto 1
Save this as continuewifi.bat, and let it run in the background! This program is continuouly attempting to connect you to the ssid, preventing the virus from disconnecting you for mode than a few seconds. While this is not technically a virus, it is more of a PUP (potentially unwanted Program).
I just tried it again, but windows wouldn't install the drivers so I had to install em
atm my only option is to tether to see if that keeps me connected on the hour, so far it hasn't kicked me yet
