Hello everyone,
I have a weird problem with a pre-built PC. It seems to occur kinda randomly, I have not been able to pin down the direct cause.
The issue occur when launching certain games, usually they work just fine, without any issues. However at a certain point, all of them start throwing errors such as "A fatal error has occured", or "Not enough video memory", or sometimes I will get a screen like this:
And after a few secounds the pc will restart with no error.
I am kinda leaning towards it being a GPU issue. But I was wondering if anyone has some suggestions on diagnosing that to be as sure as possible. I have looking at the cabling, tried multiple benchmark tests, completely reinstalled graphic drivers wtih DDU, ive tried older drivers, and messed with a bunch of Nvidia settings. The only workaround I have found is to turn off the system, not restart, that wont work. I have to fully shut down the computer and turn it back on after a few minutes and it will run fine for a while.
Does anyone have suggestions on potential fixes or some good diagnostic tools to better determine the problem?
PC Specs -
i9-13900KF
ASUS PRIME Z790-P WIFI D5 DDR5 ATX
Nvidia Geforce 4080
64 GBs DDR5 RAM
2 TB M.2 SSD
PC Specs -
i9-13900KF
Nvidia Geforce 4080
64 GBs DDR5 RAM
2 TB M.2 SSD
