Hello people,
I'm experiencing a weird problem , a pc that v built a few weeks ago the specs are:
-MSI h510 ma pro
- i9 11900F
-64go RAM
-MSI RTX3080
-MSI MAG A650BN
it keeps randomly restarting wihtout a BSOD, it can restart after 5 minutes of booting up or after 2 days, the log file when i analyse it with windbg it shows an Nvlddmkm.sys error so I did the usual sfc /scannoww, dism /online /cleanup-image /restorehealth, updated the motherboards bios, I changed the power settings , I changed the registery entery for TdrDelay, nothing worked. So I moved on to check out the hardware , I did a memetest on the RAM found 4 errors , Since I had another old pc lying around I took out its RAM and put them in the new pc, the problem didn't get solved the pc still restarts randomly, I figured then it must be a faulty gpu, I used ddu to uninstall the 3080 gpu, took it out and installed a 1660s,, the problem persists. even after changing the PSU the pc keeps restarting, today I changed the cpu took out the i9 11900f and put in an i510400f. So now from the original build I started with I keept only the motherboard and since this restart is random and it can take up to 2 days to showup I can't be sure if its the motherboard or if it the new cpu, if the motherboard works with the 10thgen i5 and doesn't restart does that mean that my 11th gen i9 is faulty or is a compatibility issue ?
-MSI h510 ma pro
- i9 11900F
-64go RAM
-MSI RTX3080
-MSI MAG A650BN
