So i recently built a computer, and everything runs great. Got my software and drivers all loaded up. The weird thing that happens is that whenever i turn off my pc for updates, sometimes when i turn it on, there would be no video signal sent to the display. I won't even hear the windows startup sound, but my monitor would act weird. Normally, it turns off when there is no signal, but it just turns on as if it gets a signal, display a blank screen and say Display Port No Signal. Then go back off, then repeat and turn back on, over and over. My fix to this is just hit the reset button, and sometimes the bios screen shows up, and everything starts up ok. In general, I have to reset the computer 1-3 times when i get this weird problem , then everything runs ok. I'm talking everything is 100% ok.
Now a weird observation that i saw that might help with troubleshooting. When plugged into my receiver & projector thru hdmi, and when my computer restarted and I was having the same issue, I actually heard the windows startup sound thru my receiver's 7.1 setup! So ive concluded that this seems to be an issue with the display not shooting out a signal upon restart??
I was wondering if this might be a side effect with 4k? Below is my system specs. Help please!
Motherboard: ASUS X99-A ATX DDR4 3000 LGA Motherboard X99-A
Processor: Intel i7 5820k 3.3Ghz 6 core
Ram: 2x Crucial Ballistix Sport 8GB DDR4-2400 Memory
SSD: Samsung Evo 840 500GB SSD
GPU: MSI GeForce GTX 970 4GB Twin Frozr V Video Card
PSU: CORSAIR AX series AX860 860W
Monitor: Asus PB287Q 4K 60Hz 28.0" Monitor
part list: http://pcpartpicker.com/user/Seebs/saved/bpMypg
When im my motherboard, I understand pretty well the basic settings, but when i go to the advanced settings, everything goes right over my head. Please advise! Thanks!
UPDATE: Just got a software update from ASUS for my motherboard and BIOS so lets see how that plays out.
UPDATE2: Looked at my motherboard while it was having the weird problem, and it was reading B2, which is the motherboard stuck on legacy option rom initialization.
