I've got a really weird resolution problem. I have a compaq w17q monitor LCD. it's native resolution is supposed to be 1440x900, 60-75hz refresh rate 32bit color. For some odd reason today I turned it on and it had lost all of it's monitor information, every time I set a custom resolution of 1440x900 it would "zoom in" it kept the old resolution but extended the borders. I reinstalled the video drivers and the monitor drivers, I re-created the custom resolution, same problem, then I changed the color depth to 16bit and the resolution worked, I switched it back to 32 and it didn't work. then I changed the refresh rate to 55 instead of 60 and the resolution worked. I'm ok with 55hz refresh rate, but I'd like to figure this out, 'cause it happens every couple of months. maybe I have a bad hard drive, monitor is dying?
system info
Windows XP Professional Service Pack 3
3.00 gigahertz AMD Athlon II X4 640
NVIDIA GeForce GTS 250
Compaq W17q Wide LCD Monitor
ASRock M3A770DE mother board
system info
