So i run Prime95 for first time and i used MSI afterburner to monitor my CPU temp.
Which it got easily at 75C.
But i could hear no fan.So i was like wtf why my fan ain't working at 100%?
So after running a few more programs i clarified the problem.
F-stream reads CPU temp as 61C (that's why i couldn't hear the fan)
and HWMonitor reads CPUTIN at 62C and TMPIN7 or package temp at 75C.
https://imgur.com/a/297ylmR
So i wonder since the CPU is such a small piece how can a part of it to be at 61C and the same time another part to be at 75C.Specially when all the cores work the same at 100%.
Should i worry about TMPIN7 at 75C ?
So i found this one:
"The CPU temp is your socket temp.
The package temp is you core temp. Keep an eye on this."
http://www.tomshardware.co.uk/answers/id-2226520/hwmonitor-readings-cpu-temps-package-temps.html
But it makes no sense...how can the socket temp be higher than the core temp?? Mine is the opposite.
